Mazda Lowering Static \  Bags Mounted On Top Of Upper Control Arms
views 3528
replies 17
following 9
dimotorsports   +1y
I'm sure some of you have seen bag set ups where the bags are mounted on top of the upper control arms... like a copstopper kit. Have any of you performed this set up, or have pictures. I am considering this to my current project and would like to see pix and get your feedback.
Thanks
Byron
blare   +1y
i dont think anyone on here as done that yet. My only thing would be to brace the upper arms a bit. The cool side is that u can use drop arms instead of drop spindles to get that extra drop.
dimotorsports   +1y
I'm really interested in doing this to mine.
I think it looks clean and there are less worries of parts rubbing the bag to create a failure. Plus, it just looks different.
dimotorsports   +1y
bump
mullet   +1y
make sure you put some good shocks on it as well, because it will ride like poo otherwise.
Mike
dimotorsports   +1y
Any one have pix of this mod? I have a few but they are not that good.
dimotorsports   +1y
bump
builtbybyc   +1y
The only drawback to this is that the upper balljoints are not designed to support that kind of wieght.
the upper arm bushings are also not large enough to support the weight properly. the stock Mazda ones are just basically screws.
for a proper setup that could be used on a daily driver, you would need to make larger upper arms with large bushings and larger balljoints.
low87dawg   +1y
look at the minitruckin with the ex cab mazda on the cover its grey it has it on the upper control arm and has a tube over the top
mark   +1y
^^ what he said
