re-indexing torsions
throwin-sparks@hotmail.com's avatar
mazm's avatar
mazm
how exactly do i re-index my torsions?
nytrdr24's avatar
nytrdr24
loosen the bolts all the way, make a mark on the other end of the bars where they hook into the receiver on the control arms (sorta like you would on a driveshaft & tranny) then you pull the bars out of the receiver, and turn them like 2 splines, making sure to do the other the same amount except opposite direction, i think it was clock wise on the driver side, and counter clockwise on the passanger side. you will have to take a pipe wrench and turn them with it to get the bolt started, then make sure you turn both bolts the same amount otherwise you'll have one side sittn higher than the other.
8
88lx
Nice answer.
mazm's avatar
mazm
thanks for the help man
nytrdr24's avatar
nytrdr24
NO PROB GLAD TO HELP!
pont's avatar
pont
ok i have heard of this but what does it do will it allow you lower the truck and keep the same ride Q or what
nytrdr24's avatar
nytrdr24
IT ALLOWS YOU TO KEEP THE LOWER STANCE, BUT STILL KEEP SOME OF THE SPRING TENSION ON THE TORSION BARS, SO YOU DON'T HAVE SUCH A ROUGH RIDE, AND BOTTOM OUT LESS.
pont's avatar
pont
thats what i thought but was not sure
8
88lx
I have to admit, NYTE has done his homework.
TH
team haymaker
alot of guys do it with older 4x4 toyotas until they can get the solid axle swap done, i was gonna try it on my mazda
