Mazda Lowering Static \  c notches - and front end ????'s
views 2493
replies 19
following 9
lowblownranger   +1y
is there any where i can order c notches that are ready to weld in. Im baggin it spring 07 but for now i need something so my frame dont meet the axle all the time i want a pretty tall notch but i really dont wanna get one in peices and have to weld the thing together. i have an 87 b2200.
I was also wondering is there any way to get my alignment a little better in the front major camber problem, i know if id get spindles and or control arms id be low and my alighnment would be better but the wife just quit working cause where having a baby
lowblownranger   +1y
oh i have 3 inch blocks in the rear with only the mian and overload springs left and the torsion bars cranked down for right now
fanninator   +1y
you dont need a notch right now. but theres not any that i know of that are prewelded. if they came prewelded it would be alot harder to put on.
schreff   +1y
Get a bolt on.
down2earthdawg   +1y
devious customs has a one piece notch all you have to do is slip it on weld it on the ends and cut out the center dont remember the price
droppedmitsu   +1y
devious' one piece is like $150 or 200 i believe
hex0rz   +1y
Got a picture of how low your truck is? It would'nt be much lower than mine because the only difference between our trucks is the monoleafing. Just wanted to see how it goes with you?
baggedb22   +1y
get an 8 piece notch and do it right man there way stronger! And as for the negative chamber problem spindles and flip ur upper balljoints...
lowblownranger   +1y
i have less then an inch between the frame and the axle they connect very often it needs to be notched !
lowblownranger   +1y
that car domain is a pic of the driver side rear tire
