What kinda Weld would do best for our frames (B2200)? Most people say Mig will work, but does it have to be Mig? What are my Options? Don't know much about welding.
phatkix
mig, flux core, arc
they will all work
mig be the easiest, flux the dirtyest, and arc is just arc lol
pont
just make sure if you get Mig that it will weld the metel your using If you get to small a welder it wont penatrat and thay will break on yea.
fanninator
how big are we talkin (mig)? thanks -bf
madmazda
Arc isnt a little much for our frame? Im not sure what would work best...
pont
Unless you spend alot for a good size welder arc would work best it gets hotter and will do the job much better I belive anyway
mazdawgrollin
arc isnt too much. just keep your voltage in check is all. should be a stronger weld, but its more difficult and takes more room with the stick. mig is the best bet for sure.
robbie
a 125 amp machine will work if you know how to weld.
pont
that is true but he said he does not know much about welding. You could always go talke a few welding classes
madmazda
i dont think i'll end up doing the welding fab part of my build, not on this one anyways...i wouldnt trust myself welding my frame. lol...so i've got someone in mind.
