Page 1 of 3
Mazda Lowering Static \  my bag list. is it complete?
views 1898
replies 20
following 10
dropped90(justin)   +1y
2 slam specialties 2500 bags. $150.00
2 slam specialties 2600 bags. $150.00
7 switch switchbox. Bagshack.net $85.00
4-link super pivot square bars. Sd.com $429.99
8-piece 8 inch notch Sd.com $69.99
4 ½ valves for fill. Sd.com. $200.00
4 3/8 valves for dump bagshack.net $120.00
Viaire dual pack 380s compressors. Gk. $289.99 bought
8 ½ gallon tan bagshack.net $65.00
Front torsion brackets bagshack.net $53.00
50’ of ½â€
elbine69   +1y
Dont forget some loctite 545 thread sealant or some teflon tape. Also be prepared to make a trip to the hardware store for some fittings. It always seems like your missing some type of fitting.
Post was last edited on Nov 11, 2007 09:11. This post has been edited 1 times.
v8mazda4ever   +1y
you might still want a pressure switch and a scharder kit just incase of an emergence fill plus I don't see any thing for your shocks so maybe a shock re-locator kit for front and rear. I personally would stay away from the tape and us dope instead to seal fittings.Also keep your mind open to flow controls as when I did cid's truck they were needed pretty bad.
slammedyota91   +1y
also, make sure you get extra metal for rear bagbrackets, i didnt see anything for a crossmember or rear bag brackets, pressure switch shouldve been included with your compressors so... thats taken care of. umm other than that its pretty complete. remember though there is ALWAYS something else lol
v8mazda4ever   +1y
ya I forgot that when buying the dual pack a pressure switch and relays come with.
yeh relays and pressure switch comes with it. rear bag plates are included with the 4-link kit. im using the 3/8s valves for dump in hopes i wont need the dump controls. ill have to see what happens to see if i need fill controls. i was figuring on dope just didnt list it. i completely forgot about shock stuff. thanks.
-justin
mazdawg(mikey)   +1y
i would suggest buying it all from one place. you can call sd and get them to bundle you a package. one place and you can save on shipping.
mazdawg(mikey)   +1y
oh and some shocks and shock mounts
v8mazda4ever   +1y
you wll still need the flow controls if you want any control with daily driving. LIke I said when we did cid's truck it was great to show off but to have some control while out driving it became a really help.
slammed83mazda   +1y
if hes running 3/8" fills and and about 150 psi he should be fine without flow controls.
If thats the case just run all 3/8 valves
