How does this work?
pocket_rocket05@hotmail.com's avatar
How does this work?
devb22's avatar
devb22
I am pretty sure that the tube goes through the upper arm to the lower arm...but how is the lift on a setup like this?
Just something I have never seen before!
Dev
ga,mazduh's avatar
ga,mazduh
well im guessing it rides the same and lift is real; good cause u dont have to worry about it hittin the upper control arms. just my 2 cents though
devb22's avatar
devb22
So I guess by doing this you would be eliminating the upper arm in a sense?
Maybe a way to get around buying A-Arms?
Hmmm...
Dev
V
v8mazda4ever
It works the same way as the bag between the the lower and upper arm but as ga,mazduh wrote you dont worry about the bag hitting the upper arm any more plus you will find that you get better lift and space is not as hard to come by also no worry if the bag will rub on the frame. Nicw set up on that truck looks really clean.
devb22's avatar
devb22
So could you still use this setup with some A-Arms?
Its def a clean setup...
Dev
immortal1 (linn)'s avatar
immortal1 (linn)
So, do I understand correctly that the bag is pushing down on a link that is connected to the lower control arm? If so, pretty slick idea.
ga,mazduh's avatar
ga,mazduh
hey just to let u guys know that truck has now been redone and its red/silver it belongs to a guy named eli frome relaxed u might remember it now, the setup is dif now cause it has a v8
devb22's avatar
devb22
I'm not sure if its a link, you would think so!
Dev
ga,mazduh's avatar
ga,mazduh
nah the upper is connected to the spindle so that is how it works it pushes down on it
elbine69's avatar
elbine69
I would think a setup like that gets a few more inches of lift than a traditional setup. The ride is probably the same.
