front bag bracket q's????????
3rdtimesacharm
i bought these brackets from aim and the sent me a pair that are the same. i was wondering if they sent me 2 passanger side, or if this is the way the set is. and does anyone have any pics on how to mount them. any help will be apreciated...
dropped90(justin)'s avatar
dropped90(justin)
ive heard of bolt on brackets but this is the first time ive actually seen them.
-justin
3rdtimesacharm
these are bolt on? do you have any clue what way they are mounted? im still going to weld them if i can.
thebeaumartin's avatar
thebeaumartin
its my first time 2
elbine69's avatar
elbine69
They bolt into the stock shock tower. I dont remember if both the brackets should be the same or not though.
Heres a pic of them installed. These were kinda half ass bolted and welded on.
Idk how big of a wheel your running but on my buddys truck with those brackets it was like 1.5" from laying out with escalades.
3rdtimesacharm
i have the suburban wheels with 40 profile tire
3rdtimesacharm
is that the driver side?
dragginmazda86 (dave)
I had a set on my truck along time ago the should be different from each other sounds like you got two of the same side. Also they sucked truck didnt go that low,bag was close to rubbing everything.where that big oval hole is the and nut started deforming and ripping the metal there. I would try to send them back and get the universal torsion bag brackets from Devon(the bag shack) or suicide doors. I dont recommend running with those at all.
elbine69's avatar
elbine69
yah thats the drivers side. Like dragginmazda86 said everything is really close to the bag rubbing with that bracket. I know the bags we took out were rubbed through in a few places really badly. If you can weld I would definitely suggest using the torsion bag brackets.
