Page 1 of 3
Mazda Lowering Static \  narrowing the rear frame on 20's
views 2477
replies 20
following 7
minimazdaon20s   +1y
so my ? is do i have to really narrow my frame to fit 20's on it . Cause i have read a lot off post on here about people putting 20's on there mazdawgs some people have narrowed there frames and some havnt.
my specs
im going to a tradtion bodydrop on 20's , i have kustumwerks upper and lower arms (thanks mom) and i have already bagged the front to fit 20's So if you can hit me back asap thanks. sned pics so i can also get ideas
minimazdaon20s   +1y
oh yea the wheels im getting are devious wheels swoop 5 , i also have 5 lug coversion the wheels are going to be 20x8.5
devb22   +1y
What do you have in the rear for the 5 lug swap?
If you have a pre-84 yota axle you will not need to narrow the frame!
If you don't, I still am quite sure that you will not need to narrow the frame...You will need to tub the firewall though!
Dev
twisted minis   +1y
You shouldn't need to narrow the frame. You just need a pretty narrow axle.
audioinmotioninc   +1y
im running 22x8 all around and i will just need a smaller axle... since i still have my 6lug... i'm gonna try and find a pre 86 mazda sundowner or ford courier rearend and swap that in there as well as have a new driveshaft built.
but so far the only things that were keeping me from laying out are my front fender lips (which i rolled the passenger side the other night... still have the driver to do) ((i might post a tech article on it....hmmmm)) and the rear is being stopped due to the axle...
just my .02
minimazdaon20s   +1y
the axle i got from the junk yard is from a 94 yota. im sayin im doing frame from the cab back, its just everone i have seen is narrowing there frames on here and on ssm.com. Cause in like a month our two in going to order my wheels but first im building my frame i just want the wheels to fit and tuck right when i order them so i dont have to rebuild the frame the second time ,im going to start building it when i get back from snowboarding in march i hvae all my metal and everthing .
minimazdaon20s   +1y
so what backspacing is everone running with out narrowing there frames, cause if i dont have to narrow my frame that would be sweet and i could just bring the rail straight back and over the axle and square it off
twisted minis   +1y
94 Toyota axle probably isn't narrow enough. Its 57.5". Only about an inch narrower than the Mazda axle. You probably need something around 3-4 inches narrower.
And Audiomotion, when you get th early Mazda axle get the drive shaft too. All you need to do is have it shortened. Something like $100 at any good driveline shop.
thanks for the tip twisted... i'm currently on the lookout for one right now... just havent been able to hit up my local junk yards until this weekend. so hopefully i'll find one then
minimazdaon20s   +1y
will this sucks it took me like a month to find that one, so now i wil have to look for a diff axle sweet. but i don have to narrow my frame right
