Page 1 of 3
Mazda Lowering Static \  static drop
static drop
views 2142
replies 23
following 11
ja2000   +1y
i just baought another mazda that is static droped but i noticed there are no front springs is that right or should they be there?
slammedyota91   +1y
No these trucks dont have springs, they are torsion front ends, The use a torsion bar and a shock
layedoutb2k (chase)   +1y
mazdas are torsion bar front suspension so there is no need for springs
ja2000   +1y
well my problem is that everytime i hit a boump i bottom out on something like metal to metal what would that be
dropndragmazda   +1y
Someone probaly has removed the bump stops, instead of shaving them down!
ja2000   +1y
so to raise it back up a little bit do i tighten (turn to the right) or lossen (turn to the left) the torsion bolt
elbine69   +1y
Tighten it
ja2000   +1y
can i tighten by hand or do i need a air gun
elbine69   +1y
Use hand tools so you can count how many turns you went on each side so its the same on each side. Id suggest spraying with with pb blaster or something like that a few times and let it sit before you try to turn them so they dont snap off.
ja2000   +1y
leave it on the ground or jack it up
