bag on bars or bag on the rear?
3rdtimesacharm
im getting ready to bag the back and im not sure if i should do bag on bars or the bag on the rear. what are the pros and cons of each. any help would be apreciated
thebeaumartin's avatar
thebeaumartin
well bag on bar + more lift,better ride - more perssure to lift,less carring capacity.
bag on axle + you can carry more of a load,lifts at lower pressure,faster - stiffer ride, not as much lift
3rdtimesacharm
so if i was trying to hop it i should do bag on rear?
burnoutboy's avatar
burnoutboy
my bags are on the lower bars. i can hop the rear tires off the ground about 3" @ 175psi. and thats with a total of 18" of lift above the axle. im also running 5/8" airline. if i was planning on keeping my truck id put slowdowns on it. just dont lift both sides at once on the freeway, it gets a little hairy
3rdtimesacharm
18'' of lift...damn what size bags are you running with?
burnoutboy's avatar
burnoutboy
re6
3rdtimesacharm
i just ordered a set of re6's for the back but i might put them up front if they fit, i have 2500 cont's up front now. if they fit up front i will get the re7's for the back.
maztang (ryan)'s avatar
maztang (ryan)
re6s in the front and re7s in the rear.
thebeaumartin
fo sho maztang b right
3rdtimesacharm
how do you have the rear set up bag on bar or bag on rear?
