Page 1 of 3
Mazda Lowering Static \  F**king Drop Blocks!!!!!!!!
views 2453
replies 21
following 15
87b22xx   +1y
Well tonight on the way home from a buddy's house, a person in front of be hammered on there breaks to a dead stop at 50mph, and in that event i had to aswell. well apparently my truck stopped, but my rear end dident.
Long story short, my 4 Inch drop blocks exploded (from the hard breaking i gather), causing my rear end to float around on the rear leafs.
so i had do drive 4 miles to a friends house to take them out, and doing so busted 2 u bolts(because they got bent somehow?). so i had to drive home with 2 holding the axle in.
tomorrow i will upload the pictures of the blocks. poor manufacturing i suppose, because they were installed properly, to my knowledge.
hex0rz   +1y
...better get that rear end and driveshaft looked out now as well!
mazdalowandslow   +1y
I hope your not mono leafed..... There is a lot of flex in a single leaf.
dhpmike   +1y
The problem was most likely the U bolts were loose. After an installation of drop blocks and driving for a while you MUST retighten these up as the U bolts stretch and everything settles in together.
You probably had the thing just a bit loose and when you hit your brakes there was just enough play to allow the axle to get out of there and break in the process.
They are cheap aluminum anyway.
87b22xx   +1y
No, its just stock leafs, with the helper leaf removed. and i tightend the u bolts about 2 weeks ago again, and they seemed alright. but who knows.
Im going to make my own blocks outa steel, insted of the b.s. cast aluminum...
90-b22dawg [andrew]   +1y
thats the way to go.... i recant the rest of what i originally said....
Post was last edited on Jul 28, 2008 04:07. This post has been edited 2 times.
mosher   +1y
now you have a reason to bag the truck
91b2200(cody)   +1y
thats what i just did ... ( stock leafs with helper removed and a 2" block tho)
sleepyspeed   +1y
I'm running 3" billet aluminum blocks, haven't had a single issue, and I have a bad habit of making tires spin.
hex0rz   +1y
6" BLOCKS?! WOW!
