Page 1 of 3
Mazda Lowering Static \  What Bags to Run?Front and Rear?
views 2244
replies 25
following 11
skrapinsask   +1y
Alright this is the last thing i have to decide before i order all of my parts. I do NOT want to have to notch my frame rails so it will clear the width of a bag. I'm using factory upper and lower front arms as well as a super lift style 4 link in the back with an 8" notch. I have seen people having to notch the front and rear just to clear the diameter of the denominator/dominator bag and this is something i would like to avoid doing . What kind of bags should i use to completely avoid this problem.
Thanks in advance.
89mazdawg(daniel)   +1y
most people tend to run Slam RE-6's, and as far as i know you don't have to notch the front for them.
skrapinsask   +1y
Yes but is it wise to run re6 bags on all 4 corners?
whats my best option for bags
All other parts on my order have been decided upon and this is the last thing i need to
clarify before i order all of my parts. I am unable to make this call and would
like to know from some one who has more experience with putting Mazda's on air.
thanks!
dragginmazda86 (dave)   +1y
I have re6's up front and re8's bag over axle on the rear. I've always installed slam bags on my rides and a couple buddies rides, but we recently used Airlift Dominators on all four corners of my friends Regal they seem like a great bag and nicely priced.
90-b22dawg [andrew]   +1y
or 2500's up front and 2600's in the rear
h2omelon(nick)   +1y
RE6's up front and RE7's or RE8's in the rear.
bgdb26k   +1y
i have slam re-6's in the front and re-7's in the back. if i were you i would do 6's up front and 8's out back
skrapinsask   +1y
denominators?
i was thinking more along the lines of air lift dominators you can get them for $50 each both 2500s and 2600s
paparoach1983   +1y
then use 2600s all the way around till you can afford bigger ones in the rear. from what i have read here and elsewhere its best not to use anything smaller than a 2600 up front.
