Mazda Audio \  What size factory speakers are in the back of an Ext. Cab?
Mazda Audio Mazda Tech
views 3107
replies 17
following 12
lucky   +1y
Well, anyone?
thetornado   +1y
i believe its a 6x8. should be able to fit a standard 6x9 though, not sure, havent tried it...
drpdmazda   +1y
depends what year you have 87-91 it shouyld be a 4" newer than that should be a 5x7/6x8 a 6x9 would require a good bit of trimming metal and you will probably run into a depth problem so definately test before you cut
lucky   +1y
Great thanks, and Yes it is a 1992. Sorry bout that.
mullet   +1y
and you can cut the metal and house up to 6x9's.. use an air saw for the best results.
drpdmazda   +1y
like i said about that, make sure you measure twice and cut once, 6x9 speakers are very deep with big magnets so i would hate to see you cut a big ass hole then the speakers dont fit
mullet   +1y
hahahahaha that would defenatly suck!
nonamedsomebody   +1y
mine are exactly 6"
2fine89   +1y
Just get better speakers / better placement for your front speakers. there is really no need for rear speakers in a properly set up and tuned system. (unless you are using the bigger speakers for bass, and not running a seperate subwoofer setup).
thetornado   +1y
where would u say is the best place for front speakers?
