Whats behind your seat???
16 following
valiant_wolf@comcast.net's avatar
valiant's avatar
valiant
I just wanted to see what people have done behind the seats in our trucks, wether it be a standard cab or extended cab. Did you put in a sub box, did you clean it up, whatever. If you have pics post em up, if not just explain what you did. I am trying to get an idea of what to do with the extra space, now that I have an extended cab.
thanks guys,
-Mike
nytrdr24's avatar
nytrdr24
i had two 10's in a box me & my dad madefor my standard cab...two seperate ported boxes for each speaker with a one piece front made so that the seat would slide all the way back.....the amps were mounted in the center over the tranny hump with the wiring concealed behind the solid front..very nice setup looked professionally built...until it got stolen
baggedb22
extra "incase" airline and a small toolbox=)
lost_b2200
Empty space where there were two little flip down seats. I put the trim piece back that goes right under the rear glass so when the box gets built it will go up to there and look good. The box will be for two 12's a 10 disc changer and a 1200w amp. I do need to take the seatbelts out of the corners but I didn't want to deal with those metal plates the night I removed everything else.
valiant's avatar
valiant
nice guys keep em comming.
one thing, lost_b2200, will the 10 disc changer skip being in with the 12" subs or do those changers not skip? I wanted to get a disc changer, but I didnt know if those skiped more than the tuner, but I wasnt going to mount mine in a box. Good ideas though.
thanks guys
-Mike
slammed83mazda's avatar
slammed83mazda
haha yes same here, + quart of oil, flashlight, box of poptarts, brake fluid
lost_b2200
It might! It was just sitting in the hatch of my mx-3 for about a month and didn't skip very much then. I wanted to mount it vertically and flush with the front of the box right in the middle so it could easily be accessed from the driver seat. Heat may be an issue so it might be port-cooled. We'll see.
valiant's avatar
valiant
I think they make those little fans with probes that turn on to vent the box and amp area. that might work for the cd changer too. can those be wired in to any tuner, or do you have to have a special one?
-Mike
nytrdr24's avatar
nytrdr24
to prevent the skipping just get a portable music device (i-pod, etc.) and use it instead of the 10-disc changer.....it can hold 10 times as many songs, is a lot less hassle with the wiring, & more compact...at least that is my plan...
lost_b2200
The one I have is an Audiovox Prestige it connects directly inline with the antenna. (Antenna -> Modulator -> Head unit) Sound is great and no interference or anything. And it has it's own disply and controlls. Also for the idea to use a portable, you can get the Audiovox modulator to pipe in sound from any source directly into your receiver through the antenna. It has selector for one of two frequencies.
