dash lights
dash lights
1lob2k
Has anyone had the problem of the dash lights working/ not working half of the time? if so what did you do to fix it or point me in the right direction
crazymikey's avatar
crazymikey
when your dash lights stop working,do your tail lights and parking lights stop working as well?
I just had a problem where I was blowing the tail light fuse,which made my running lights and dash lights go out. I never found the cause of the problem,but after randomly blowing fuses for a week,and going through about 15 fuses,it seemed to have cured itself.
If your problem is like mine,check the wiring on your radio,make sure there are no exposed wires causing ground outs,and get under the truck and check all your grounds on the frame,as well,take out your tail lights,and check your wiring harnesses,because water and muck likes to get up in there and cause problems.
Hope that gets you on the right track!
1lob2k
actually, my problem is the lights will be bright one minute, then dim, then out, then bright and back and forth.
crazymikey's avatar
crazymikey
weird. Does everything else work fine?
1lob2k
headlights work fine, turn, and taillights aswell as brake lights. I figure there may be a short or something somewhere, or the interior dimmer may b going bad
hocbj23
There is a dash kite dimmer switch on ur dash.Going bad sounds like.I think new they are north of 100 bucks.I ahve a used one that works fine if u want to try it.BJ
mazm's avatar
mazm
yep sounds like a dimmer switch, i had to put one in my truck
dimmer switch.....definatly
PB
pimp b2200
[quote="crazymikey"]when your dash lights stop working,do your tail lights and parking lights stop working as well?
i has the same problem and found out it was 1 of the 2 corner lights, after i unpluged them i stopped blowing fuses
carolinasled
mine was doing the same thing. i bypassed the switch until i got another. i'm on my second dimmer switch.
