Mazda Audio \  Capacitor?
Capacitor?
Mazda Audio Mazda Tech
views 1468
replies 17
following 9
hex0rz   +1y
Alright, so, is there anyone out there that uses a cap?
Out of all the audio thnigs I have learned i still cant figure it out!
My problem is, I took the cap off the capacitor to look at the circuit board and whatnot. Now, I don't remember what way it went back on. The cap will go on both ways, and the cap has a +, - on it which tell you which way it gets hooked up! I have tried to ask the person I bought it from, but I'm not important I guess.
In the description it says it has Polarity protection. I have tried to look this up and see what it means. Does anyoen know?
I tried to take it to Car Toys once to see if they could find out the polairty on it for me, but no good.
I want to use my cap, but if I screw up the polairty, the cap is toast!
mazdamn   +1y
Caps play a VERY small part with sound. I ran one, and it did NOTHING but tell me voltage.
Positive to the battery + and amp +.
Negative...just ground it.
Do the "Big 3" upgrade?
1. 4g wire from alt + to Batt. +
2. 4g wire from Batt. - to engine block.
3. 4g wire from Batt. - to body.
And YES, this works like you just got a better alt and battery. Cleans the signal and all that. The 4g can be larger, but I wouldnt go smaller.
hex0rz   +1y
Actually, I have a HO alt. that puts out 210 amps at high rpm. 170 at about idle.
I have a BIG 3 upgrade and wrote the techie on it here! Which is in 0ga.!
Even with this and my optima yellowtop, my lights still freakin' dim on big beats. Last night, I was commuting home I could notice that it dims alot on hard beats.
I have a 4farad cap and only 2000 watts I'm punching out. its more than enough, and its the last upgrade I have for my sound system.
i just need to know that if I hook up my cap. wrong will it get toasted? If I have pol. protection on it, does that mean if I hook it up wrong, will it just not work and I still have a chance totry it the other way? Heck, I might be screwed now too. I have'nt even charged it and how would I be able to do that if I dunno which one the + terminal is?
mazdamn   +1y
A cap wont help. HO alts, and big 3, with deep cycle battery....dont put a cap in. No need for it. on a big beat.....caps are good for a 'burst' then they are recharging. So, sell the cap, and live with the dim lights. Get a voltage regulator and try that, put larger wires on the amp. At 2k, I'd assume ur running 0g or bigger. If not, you should be.
sierrax   +1y
Use a volt meter and put the Positive lead on one post and the Negative lead on the other. If it shows a negative symbol then you have the leads backwards. If not then you have them correct and mark the posts.
hex0rz   +1y
My HO alt. has an internal voltage regulator. As for as wire size, I run 4ga. to my dist. block. from the battery. 4 ga. off the block to my 2 amps that run for each sub. The 3rd amp is only 200 RMS. This one runs 8 ga. I believe, from the dist. block.
With only the 2 amps running that is only 1600 watts peak. The amps together have a fuse rating of 100 amps. I highly doubt my alt. is defective in any way because I still have a good battery and my truck still runs, after all this time. The alt. does not whine either...
I can't figure out why it dims... lol. My HU has a volt display, and it is between 14-15 volts when running. 12-12.5 when truck is off. When it hits a beat it will go down to 11-13 and jump back into 14's after the beat.
Hey sierraX, thank you for giving me that tip!
phatkix   +1y
my experience a cap is a waste of money, i used to compete in spl, and the only thing a capacitor ever did was show me #'s then gradually wear out......
i got rid of my dimming lights by running a 210 amp max alternator, three batteries.... two yellow tops underneath a false floor and a basic interstate 850cca
and this was running more than 4000 watts rms.
dragginmazda86 (dave)   +1y
I have used myself in my own rigs and sold all kind of caps and they really don't help much. In my girlfriens car with 2 JL 15 inch W3's, Roccford BD1000, 0 gauge wire, Optima red top, high output alternator,with 4 1 farad caps didn't help a bit with dimming lights. I took out the caps and installed a Kinetic HC 1400 cap/power cell in the trunk no more dimming lights. I think it cost me around $320. Heres a link.
mazdamn   +1y
Battery to dist. block is 4g?
Dist Block to 2-4g cables to 2 amps?
Dist Block to 1-8g for 1 amp?
4g to 4g,4g,8g.....NOT good. Your amps are starving for power. Whether you have 2 4gs comin from the block to each amp, OR 1 4g from the block to 2 amps. Its not enough. Just for my 2100 HCCA and 225 HCCA I ran 0g for 2100, and 4g for 225. And trust me, my lights barely dimmed. I dont think its the alt or cap. I think ur starving ur amps for the power they need. This could lead to them clipping, they MAY be already....go get a run of 0g or a lil bigger, run that from the battery to the dist. block. You'll prolly notice a difference right away.
solow93 (ryan)   +1y
I have a stinger 1 faird and it seems to help with my light dimming. I have a 800 watt. pioneer amp and 1 10" rockford it works great for me my dimming problems is gone.
