Mazda Audio \  instrument lights not working
Mazda Audio Mazda Tech
views 5760
replies 18
following 6
thamazda   +1y
Whenever I turn on my lights none of the lights inside come one can someone help me with this when I bought the truck the dash was out of it so I don't know if they worked before.
Thanks
mazdaman82   +1y
did you make sure you pluged all the plugs in right? and make sure the bulbs are good? do the tech and things work just no light?.......try the dimmer it may be turned down or just bad,or if it is unpluged it will not let the lights work
midnightmike   +1y
the dimmer switch is most likely the problem my friend
the best way to check is with a test light, pop off the trim and use a test light, turn on the parking light and check the connections on both side of the switch
thamazda   +1y
Thanks guys ill try it when I get off work you can keep the suggestions coming
Post was last edited on Apr 13, 2010 07:04. This post has been edited 1 times.
thamazda   +1y
Yes the tach and everything works
cham-b   +1y
i just had ther same problem , after i went through all the fuses , i changed dimmer switch and all problems were gone!!! G.L
thamazda   +1y
Were can I get a new dimmer switch?
mazdaman82   +1y
you can find then in a pick a part yard, not sure if the parts store has it or not,i got one not to sure if it is still good tho,was when i took it out...lol
thamazda   +1y
it was not pluged in, the plug was hiding behide the dash
mazdaman82   +1y
good to hear man...
