Page 1 of 4
Mazda Projects \  ahoyyy
ahoyyy
Mazda Projects
views 3638
replies 30
following 12
b22bmber   +1y
whats up
ordering the stuff to bag the rear in the next week or 2
i was thinking about still doing 2500contitechs in the rear instead of 26 what do you all think?
and what are your opinions on bag on 2link bars since im just running front and back? good lift and better ride right?? but how about reliability?? and holding together?
also my truck is in need of a carb wut do you think weber 32/36
or weber 34? and will either of them bolt right down?
stuf for the rear
2-contic tech 2500
2-1/2 ascos
2 link suspension
bags on link bars
-- im making my own bag brackets and gussetts
i have some ectra metal layin around and
might try to make my own c notch]
if it doesnt come out great im just gonna
order a bridge kit from suiciide doors
v8mazda4ever   +1y
I am not a fan of the 2 link set up as you need to run a pan hard bar and the only time the rearend is truly centered is at were you set evrything in at. I would run the bigger bag as you will find you will get a better ride. Myself and a couple others that have done the smaller bags have changed to the 2b7 bags and the re-7 bags for a better ride. just my 2 cents.
immortal1 (linn)   +1y
If you are dead set on the 2 link, you might consider a watts link instead of the panhard bar. Bigger bags will definately ride better in most situations. With a front/back setup I would definately run a sway bar in the front!!!! Air pressure will transfer during a hard turn from the outside bags to the inside bags (severe lean/sway).
b22bmber   +1y
thansk alot fellas
yeah i probably will go with the bigger bag
but i am pretty much dead set with a 2 link its cheap and quick
and yeh im aware that i need a pan hard but i have thought about the watts link also
i just dont know yet
mazdamn   +1y
BODY ROLL!!!!!!!!!!!!!!!!! WAHOOOO!!!
toddluck   +1y
so does a 2link connect to the stock fron spring perch??
b22bmber   +1y
yeah just have to buy 2 bushings that are like 10 bucks a piece
cuzz im making my bars on my own
dropped90(justin)   +1y
what size bag is too big for the bag if your doing bags on bars?
b22bmber   +1y
my buddy has a 92 s10 single cab with bags on bars and he has contitech 2600 with no problem at all
okay i was just wondering because the mazda parts truck ibought had re-8's over axle at one time. what do you gain just better ride and more lift?
