Weber issues
avalos.ca.christopher@gmail.com's avatar
Weber issues
b2200beast's avatar
b2200beast
Probably already been posted but. I just installed a weber carb 32/36 on my 90 b2200 standard. I thinking installed everything right but it seems to backfire. Like when I start it it revs real high then drops down and gas comes flying out the top. How can I fix this? I think I connected everything right. Those anybody know of a post that can help me out
Sent from my iPhone using Tapatalk
joemazb2600
Cusser's avatar
Cusser
Did you replace the return spring with a stronger one? At least a few years ago, the supplied spring was VERY weak.
Also, did you check the adapter plates for flatness? And sand flat use a sheet of glass as surface? And use sealant such as Permatex Aviation on the gaskets? And make sure that ALL the vacuum ports are plugged, as you only really need the one to the distributor advance. These can have significant vacuum leaks otherwise.
b2200beast's avatar
b2200beast
Where does the distributor advance connect to?
kylesj6033
the distributor advance connects directly below the carb on the vacuum on the spacer for the carb. I used to have a picture of it but don't at the moment but works great for mine
Sent from my VS950 4G using Tapatalk
kylesj6033
it's on passenger side of carb spacer facing the fender well.
b2200beast's avatar
b2200beast
Okay. You don't have the canister or the egr connected?
kylesj6033
no man. I'm fully deleted. only vacuum I have is brake booster, pcv valve and vacuum advance.
b2200beast's avatar
b2200beast
The brake booster connects to the carb?
Sorry I'm a newbie to carburetors
kylesj6033
no it hooks to intake
