Page 1 of 4
Mazda 2.2L \  anti freeze pukin out overflow
views 4105
replies 33
following 9
doublel24   +1y
New member here, I have a 88 and it just started pukin anti freeze out overflow tank.I just put a new t stat in aand it still does it. Could it be the water pump? Any suggestions would be great. Thanks
dan woodland   +1y
Welcome!
It's over heating. You'll have to see if the radiator is blocked. Run the engine, not to over heating, and see if the entire radiator gets hot
doublel24   +1y
Ok thanks. The motor never got hot it jus builds pressure and pukes out overflow and the anti freeze isnt hot. I will check what you said to do tomorrow.
dan woodland   +1y
Since it didn't get hot, change your radiator cap first, an easy, cheap fix.
doublel24   +1y
OK I'll try that. It was running fine the other day then I noticed it was leaking antifreeze. Pulled it home changed t stat today and let it run and started flowin out the overflow.
doublel24   +1y
I bought a new cap and still have same problem. Ran with cap off for a bit and didnt see any bubbles. I have a new t stat. The radiator never got hot. Could it be water pump? What should i try nxt? Thanks
alittlelow   +1y
did u make sure the t stat was going in the right direction
doublel24   +1y
Yes put it in the same way old one came out.
emjay   +1y
Worst case scenario you have a blown head gasket, that has been my personal experience with my old Civic. As the others said, it could be a clogged cooling system, or a collapsed lower radiator hose.
doublel24   +1y
I pulled the spark plugs out and they were wet. Would this be head gasket issue? The truck ran great and had no issues till the other day.
