Mazda 2.2L \  valve seals
valve seals
views 2314
replies 19
itfitz98   +1y
89 b2200
So im halfway through the process. I loosened up and took out all the rocker bolts. I was able to slide the rocker parts toward the back enough to get the back three cylanders done, however i cant get the front two to budge because of the cup thingies on the head for the oil ports.
anguswilly   +1y
Typically, you would take off the complete rocker assy in on piece.
itfitz98   +1y
Thats what i thought but the front hold down where the rods fit in to wont come loose.
Is there a bolt im missing someplace?
anguswilly   +1y
Oops, sorry, I had 2.6 in my mind (even after years of building 2.2's
itfitz98   +1y
I was hoping to avoid that.
zanzer   +1y
As Willy says, there are 2 bolts behind the timing sprocket that attach to the #1 cam cap through the front backing plate. You'll need to pull the cam sprocket, distributor, and upper backing plate. The cam caps are doweled and the #1 cam cap is sealed to the backing plate with a gasket.
itfitz98   +1y
so I think what I am going to do is roll with the back three cylinders and leave cyl #1 alone for the time being. I dont really feel like getting into the whole timing mess. If I need to do a timing belt or head gasket in the future I'll do it then. I just dont have time to do all that right now. Besides with three of the cylinders done it should take care of 75% of the problem, right?
zanzer   +1y
I'd do them all since you're already 80% of the way there and be done with it. The timing stuff isn't that hard. Put the engine on #1 TDC compression stroke, make sure all the timing marks line up, install the distributor with the rotor at 9:00, set the timing. Timing belts are cheap on RockAuto and it would me a great time to install a new one. Also a good time to install a new cam seal.
If you have 3 cylinders running clean and 1 cylinder that's still smoking and trying to oil foul, the engine isn't going to run as smooth or efficiently as it could. Also, 1 dodgy cylinder with 3 good ones is more noticeable than 4 weak ones.
Cusser   +1y
Timing belt stuff is pretty straightforward. See the B2200 tech Section on MazdaTrucking.com
anguswilly   +1y
The distributor has a pointer and a dot on the end, install it by using those.
