Mazda 2.2L \  Speedo gear
Speedo gear
views 2332
replies 15
muth_33   +1y
1990 b2200 speedo is not working. I disconnected the cable from the cluster and also from the piece that runs into to tranny and spun it by Hand to see if it was broken also used a screwdriver to turn the fitting at the back of the cluster to see if it would raise the needle. Both worked. So now I know it's the piece going to the transmission. The problem is that I can't find the part anywhere. Any ideas on where I could get one or even the pinion gear or what gear I need? Any help would be greatly appreciated.
dan woodland   +1y
You sure its not the end of the speedo cable that fits into the transmission? I think it's more common for cables to break than the transmission portion.
muth_33   +1y
I am not sure, I didn't pull that off and check it, but either way I can't find that part either
dan woodland   +1y
Look at the transmission end of the speedo cable, it should have a small round tip with a "tab" that looks like it was pinched. if that is sheared off you'll need a replacement.
I have some available if you need one. Dan
muth_33   +1y
I'll check it probably Thursday night. I got to thinking that since I have an aftermarket cruise control that was installed in the truck that piece might be a bit different with the speed sensor. You know anything about that?
dan woodland   +1y
I'm not sure what kit you have but last one I installed had a sensor attached to the drive shaft for speed input, OEM cruise units take the signal from the speedo.
That may be part of your problem.
muth_33   +1y
It's on the speedo cable, there is a piece that comes off the transmission that's maybe a foot long that it picks the speed up off of, that piece has a screw in adapter that connects to the main cable. Just two wires running to it, both under the same point.
scotch   +1y
Share some pics of it you can.
Cusser   +1y
I installed an Audiovox aftermarket cruise control on my B2200 back in 2003, and it had the option of putting a magnet/pickup on the drive shaft or running a wire from the coil negative terminal.
muth_33   +1y
here are some pics of the cable I need, at least I think this is the problem. I pulled the other part of the speedo cable off and it works, so this is next to check.
