Mazda Engine General \  A Few More Problems
A Few More Problems
views 1203
replies 15
following 6
dispatcher420   +1y
hey i have a 91 B2200 and i took the head off a 2000 and changed the timing housing and had it rebuilt ported and polished and now the thing wont start it blows out the carb and wont fire so i was thinkin it was the timing but i cant figure it out does anyone have any ideas or is it just not gonna work with that head?
any help would be great its been sitting all winter and now i want my toy back thanks
mike
Post was last edited on Mar 25, 2008 03:03. This post has been edited 3 times.
lofosho86   +1y
come on guys...help a brother out!
jmzcustomz (jeff)   +1y
I would make sure that the top end and the bottom end are aligned for tdc (top dead center) on cylinder 1 then se the dist accordingly. Might work.
dispatcher420   +1y
yeah i tried that but i cant figure out the cam tdc, it has a 1 2 3 4 with arrows and the book said align it up with a 0 and the cam pully does have three little numbers and one was a 0 and i tried that along with all the rest. and on the crank the timing mark always go to tdc easy but is there a comp. and exh. stroke when lining up the crank
pont   +1y
put the number 1 piston TDC there is a mark on the cranks timing gear and anther one on the oil pump. Just line those 2 up. Now this is were your power stroke will come into play. with the valve cover off turn the cam till you see the number 1's intake valve open and close then turn it to the 1 on the cam sprocket comes back up and line up the arrows.
put the belt back on. then put the Dist cap on and mark were your number 1 wire is. then take the cap back off and and when you put the dist in make sure the rotor button lines up with your mark. try and get it were the bolt that holds the dist in will have the same amount of adjustment on each side. then put your cap back on and put all your plug wires back on in this order 1 3 4 2. That is what I have always done and my starts every timing on the first try
dispatcher420   +1y
Awesome thanks alot for your help i got it running tonight everything was just a little off, so i timmed it just so it would run fixed all the little leaks and everything but now its running supper rich and misses and barely runs, wont stay running if i hit the gas at all, and it chatters really bad, so i think the rockers need adjusted since i switched to manual lifters but any ideas on what else is wrong?
dispatcher420   +1y
its a 91 b2200 with a 2.0 portded and polished head an accel coil and header do i need to change anything from stock timming maybe?
pont   +1y
adj the lifters then see how it goes
mazdamn   +1y
and dont strip those nuts. lol. they're $12.95 at the stealership.
dispatcher420   +1y
Agian thanks for all your help i adjusted the lifters and now it runs good, now it just idle's around 2000-3000 and if i try timming it so it runs slower it dies out around 1500 and wont idle under that any way to maybe adjust the the carb or is it still out of time?
