Mazda Engine General \  not running right
not running right
views 920
replies 17
following 9
maximum_overdrive   +1y
when i slowly press the gas the truck will run fine but when i stab it it will cut out and if i hold it there the rpms will drop until i let of the gas again ,and if i hold it to long it will die , what could be causing this ? i have a weber conv.
toddluck   +1y
check the choke and the timming
bodied b2600zx (josh)   +1y
similar to my problem except mine is fuel injected 2.6L. I dont know what the deal is
thebeaumartin   +1y
fuel pump not puttin out pressure? or check your fuel press.reg.
i dont have a fuel pressure reg. but i do need to check the timing
hocbj23   +1y
check the linkage on the carb as well.When u step down hard on the gas the secondary should open up.If the linkage is loose or the advance spring is broken shesa no work and the truck will stumble.BJ
audioinmotioninc   +1y
maybe clogged or very dirty fuel lines not allowing enough gas to get to the carb.... disconnect the fuel line going to carb and then turn key on to see if fuel pumps out alot or a little......then if it is pumping good flow then check the carb linkages.
toddluck   +1y
i thought the weber had to have a fuel pressure regulator??...maybey is flooding itself out
it seems to be a problem with the secondarys ,it does not seem to open fast enough. is there a adjustment on there to fix it? or is a rebuild needed ?
thebeaumartin   +1y
my weber would stall out after running for 20 min. without a reg. now that i got one it runs great
