Mazda Engine General \  Please Help With an Electrical Draw.
views 976
replies 14
following 7
rreyna   +1y
im experiencing an electric draw. It will kill the battery if you leave the fuse in all night. I do know that the draw is on the fuse that's under the hood, It works the constant hot to radio, dash clock, dash lights, dome lights, and running lights. I know this because if pull that fuse i experience no problems besides the obvious. Whatever it is its on the fuse under the hood. Any help would be appreciated.
P.S. I just signed up a couple of days and im amazed as to the info on this site. Its been 8+ years since ive built a mini and had no idea so many still did. Last mini was '87 S10 body dropped on "18's back in 1996. It feels good to be back.
thebeaumartin   +1y
you got a bulb burned out or your door pin switch is'nt working check those
90-b22dawg [andrew]   +1y
man mini truckin is a way of life..... billions of bagged bodied minis all around the world... you have a system in your truck?
thebeaumartin   +1y
oh crap no shit when you pull the fues it turns off the radio and turns off the amp......dude what was i thinking haha
rreyna   +1y
no system. would no corner lights pull a draw. i just bought this truck less than a week ago. its all stock. the wires were just cut where the corners were.
rreyna   +1y
would the memory on the head unit or the dash clock pull enough over night for it not to start?
id say that if the light wires were cut... check them to see if they are touching each other and aren't just taped over (rigged).... stock deck? the memory on the clock doesn't pull hardly any juice even with it light up....
mazdamn   +1y
How old is the battery?
midnightmike   +1y
the radio could be the draw too, ive seen that happen a few times
rreyna   +1y
cranked right up this morning. well see over a couple of days. thanks for the input guys. i guess its fixed for now. must have been the head unit.
