Page 1 of 3
Mazda Engine General \  Where is my coolant going?
views 1458
replies 26
following 12
long roof   +1y
I took out my thermostat awhile back cause my truck was getting hot. A few weeks later I noticed it was getting hot again... I was low on coolant. Then again a few weeks after that I was low again. I can't see it physically leaking out anywhere and the reservoir is also always empty... Any ideas?
low down89   +1y
could have a pin hole in the rad
long roof   +1y
I don't think so... Because it would be spraying out when the truck got hot, right?
low down89   +1y
more than likely. i had a leak once due to a clamp being slightly loose and couldnt even see the coolant dripping out
long roof   +1y
Hmm... This seems like a lot of coolant lose for something like that. That's why I'm dumbfounded.
toddluck   +1y
ok put a new thermostat in and replace the radiator cap ...it sounds like the cap is bad and your slowly losing wather through that you wont notice it cause your driveing and its evaporiting past the cap...and never run these things without a thermostat..they are cheap
layedoutb2k (chase)   +1y
it does sound like the cap is bad, because it willl cause the coolant to boil and evaporate a lot. the system has to stay pressurized for it to work properly.
mazdawg(mikey)   +1y
any white smoke on startup? could be a blown head gasket if you do. the water is going out your exhaust as steam (white smoke). if not, then its your cap like the others said.
long roof   +1y
Hmm... It might be the cap then. No smoke at all.
hex0rz   +1y
Exhaust smell sweet? Check your heater core, it could all be leaking inside the cab.
