Mazda Engine General \  Engine Cleaning
Engine Cleaning
views 816
replies 11
following 10
trplezro   +1y
What's the best stuff to use to get all this old caked on oil and everything off of my engine parts so I can paint them with dignity?
Also, What're the best prep methods for painting engine parts?
dragginmazda86 (dave)   +1y
I use a product called "oil eater" it says to dilute it but i spary it on pure works well if not try brake cleaner to get most of the grime off.
slammed dimensions   +1y
At the shop we use this stuff called purple power, you can pick it up at most parts stores, works extremely well.
fakehawk   +1y
Simple Green isn't that bad either
For painting engine parts, you want to use some high temp paint. Just make sure that the area you want to paint is extremely dry. I would suggest spraying carb cleaner on a rag and wiping down the area you want to paint.
bodied b2600zx (josh)   +1y
Oven cleaner also works great
trplezro   +1y
Thanks guys. What about for sanding all the baked in stuff off?
hocbj23   +1y
Dremel with a wire wheel is easier.BJ
layedoutb2k (chase)   +1y
sanding on baked on oil will just clog up your sandpaper real quick. like hojbj said, wire wheel on a dremel or on a drill will take it right off.
elbine69   +1y
Simple green does good work at taking grease off.
