help please!!!
help please!!!
jo2200
ok here it is guys i have an 88 b2200 and im only getting like 200 miles per tank and i dont know if maby its geting to mutch air or if it getting to mutch fuel? im not sure i tried to adjust the fuel air screw and nada it running ritch as hell and dont know what to do about it
jester's avatar
jester
Need more info on your truck. What carb, exhaust, last tune up etc...
jo2200
last tune up was maby a month ago and it has stock carb stock exhaust but i elminated the tubes going to the breather and cut the mettel around it so its an open filter but it was running like this before i did all that
jester's avatar
jester
I'm pretty sure the stock carb is a closed unit and the only screw for adjustment is the idle screw. Does the truck seem kind of lower on power than normal? If so I would suspect that your catalatyc converters are starting to plug up. Also when you eliminate the emissions junk on the stock carb, the computer puts itself into a "limp" mode and makes the truck run richer. Because you said that it was doing it before you modified it, I would guess that either one of your emissions solenoids failed or maybe a vacuum leak somewhere in the 100 miles of tubing? Just go for a Weber and a header. well worth the $$$, it'll pay for itself in headache medication alone lol
jo2200
ok thanks man. but can i fix the emissions sensor for now untill i get the webber?
konzern1's avatar
konzern1
yeah i have the same problem, i guess my ratio isnt right cuz my trucks computer goesn into limp mode and runs really REALLY rich, i just disconnect one of the vammums right under the carb so it wont do that, how can i adjust my air/fuel ratio?
jester's avatar
jester
Buy a Weber, The stock Nikki carb is a sealed unit
slowfe
does it still have the original nikki carb. on it? if so that is more than likely your whole problem. My carb. was the same way, the fuel enrichment solenoids go bad on them and cause them to go rich. If you say ur only getting 200 hundred mile to a tank i would say its probably the carb. Mine was doing the exact same thing. Just my thoughts.
hocbj23
regap ur plugs to .035,advance ur timing to 5% BTDC,replace ur air filter with a new factory one or a Kand N.Clean the carb with carb cleaner.Check all ur vacuum hoses for leaks.Tighten the bolts at the carb base (be gentle and use a torque wrench).Clean ur EGR valve.That will help some till u get a new carb.BJ
jo2200
thanks bro that helps me out a lot.
kia swap
last post by Brody +1y
51
