Page 1 of 3
Mazda Engine General \  oil in overflow tank?
views 2167
replies 25
following 8
bee.em.doubleyou   +1y
how is this even possible never seen sucha thing in my entire life. granted i'm only 19.
helphelphelp.
and what the best way to cure the old mazda tick.
read alot about it. but can't determine the best way to get that job done.
thanks.
mazdatweaker   +1y
The head bolts lose their clamping tension over time.
The picture from another thread shows the ten head bolt holes in the block.
From the picture, you can see the oblong, water jacket holes.
The big amoeba looking hole between cylinder two and three is the oil return channel.
Where is drops down, just above it is the oil pressure (feed) port for the cylinder head.
Just above that is a water jacket hole.
If the cylinder head bolts get loose, oil pressure at 45 psi (or less) can get pumped into he water jacket.
You seeing oil in the overfill bottle indicates you have a head gasket that has a seep leak.
You might be able to retorque the head bolts to 65-70 Ft-lbs and avoid gasket replacement if you act quickly.
If you retorque the head, oil that is being diverted into the water jacket (with a resultant loss of pressure) might get into the head, and stop your lifters from ticking due to inadequate pressure.
baha   +1y
Wow very nice Tweaker, seems like you could probably write your own manual for these trucks
hocbj23   +1y
Tweaker! Nice post dude.Where u been?BJ
wow, thanks so much!
i've been searching long and hard about this.
and that answered both questions fully.
thanks very much tweaker!
mazdawg(mikey)   +1y
good job tweaker. i learned something new today.
okay, so i recently swapped in some solid lifters. and retorqued the head, but still getting oil into the water. pleasepleaseplease don't tell me i have a cracked block.
warped head? bad head gasket?
should i try a new gasket, and having the head shaved?
90-b22dawg [andrew]   +1y
more then likely bad head gasket... if the head was cracked itd be over heating right?
right, and it's not. drives flawlessly, without a miss or anything. it's got me all f***ed up. i have no idea. and if the block was toast it wouldn't quit smoking. and it does, i have new valve stem seals installed in it. and i'm still just running down the line of things chasing the smoking problem.
