Mazda Engine General \  Clutch Install
Clutch Install
views 1429
replies 12
following 7
staticb2200   +1y
Hey guys how's it goin? Does anyone have any kind of write up or tech article on how to install a new clutch on an 86-93 b2200? Thanks alot!
oldspice213   +1y
im lookin to do the same hopefully someone post some good info
oldspice213   +1y
im also located in pa 17821 are you close static?
staticb2200   +1y
Looks like im about 105 miles from you. Im in 18040. You going to bowling nats?
oldspice213   +1y
oh easton,pa rite? and no ive never heard of that wheres it at
mazdalowandslow   +1y
Eather pull engine and tranny or, lift vehical and pull tranny out via removing the crossmember. you have to disconnect the drive shaft. disconnect the slave cylinder, there are 2 14mm bolts the hold the tranny to the crossmember. from inside the cab disconnect the shifter. then there are i think 6 bolts around the bellhousing. then the tranny will fall out. (its fun to bench press) so use a floor jack and a good friend. then you will have access to the back of the motor and the clutch. there are 6 or 8 12mm bolts around the clutch. I would recommend getting the flywheel resurfaced. Also recommend buying gear oil sence you will pull the drive shaft the oil will come out.
gordy   +1y
Low and slow covered it i think, It really isnt that hard when you get into it. It all just kinda fits together, just make sure everything is lined up right, oh and put the clutch disc in the right way lol.
staticb2200   +1y
Yeah thats right Easton, Pa. East Coast Bolwings Nationals is a big winter gtg for minitruckers @ a bowling alley in Wilkes-Barre, Pa. No need to bring a truck its not a show, just come throw balls and drink... Its definally an awsome time.
11th Annual
CHACKOS FAMILY BOWLING CENTER
195 Noreth Wilkes-Barre Blvd
Wilkes-Barre, PA 18702
staticb2200   +1y
Thanks alot bro I appriciate your help! Yeah I figured that it woldnt be too difficult . I do alot of honda motor swaps and stuff like that. I have done a clutch on my 1.8t VW also, just never on a mazda or truck for that matter. Again thanks alot.
mazdatweaker   +1y
I have done this a couple times.
I use slings under the transmission run from one frame rail to another. I put about 4-6 inches of slack in them. Then, I can pull the transmission back and the slings hold it suspended while i swap in clutch parts. It saves having to jack it back into position. You tighten the slings and kind of caterpiller the transmission forward to reinstall it.
The shifter housing has 12mm-headed bolts bolts that you can get to under the truck. . . you don't have to pull the shifter and the boot from the top.
Drain the transmission oil before you pull the driveshaft.
There is a pilot bearing inside the crankshaft tail that will need replacing at the same time you do the clutch.
You might want to change out the rear main seal since you will have access to it if you drop out the flywheel.
To get flywheel bolts tight or loose, and keep the flywheel from spinning, you can put one of the transmission bolts back in and use it as a pivot point with a pry bar.
The emergency brake cable runs across the top of the crossmember support, and if you have the emergency brake applied, it is really hard to get the crossmember free of the cable.
