Mazda Engine General \  high rev
high rev
views 1596
replies 17
following 6
joehussey   +1y
Im looking at a complete rebuild and i want to make atleast 150 hp and i want it to rev up a little more what are some answers to this problem oh and i want it to be bullet proof. toyota has lc engineering is there a web site like that for the mazda
toddluck   +1y
150 out of what?
baha   +1y
What year is your truck? I'm sure you have a pre 94 but if you have a later model check out this site for 2.0, 2.3L parts ?
What do you mean by rev up more? You may want to look into advancing the timing
joehussey   +1y
It's no secret that the 2.2 is a lower reving engine. I do like it though
I read a post that a guy used a conversion guide to put better pistons
In a fe3 and a few otherthing. I'm sure some of that would work as long as they are not head parts obviously.
themdot   +1y
You can Lighten the flywheel to make it rev faster but I'd look into some sort of scatter shield because it can get pretty messy with those stock flywheels coming apart. We used to do it with our hondas back in the day,it helped considerably.
joehussey   +1y
That might help abit but I was looking more toward something like forged pistons, cam, header, moroso oil pan,
Quad carb set up special valves port and polished head. Stuff to realy increase the power
themdot   +1y
My fault I thought you just wanted it to rev faster, Honestly do a swap if you really wanna make power. 150 is definately obtainable but thats alot of money and work for 150hp IMO
joehussey   +1y
I kinda just want to see if i can do it. The problem is finding the parts. I'm not sure if the post I read eRlier on this is for Mazda or the ford 1.8 pinto motor. I can do the carbs my self but cams and a header would be nice. And of course I need to rebuild the bottom end
joehussey   +1y
Come on guys help me out here. What else can be done to this thing. I'm thinking of running steet bike carbs custom cam, header, head, and exhaust. What over all performance do you think can be gained by this
oldskewlkool   +1y
cam. from usa cams or somthin
