4g64 block, 4g63 head
mightytyler
Ok... I have a 1990 2.4l MM. I have been researching how to put a 4g63 head onto my 4g64 block. I have found many different sources. I was wondering if anyone could tell me how to do this exactly. I know i have to block off 5 oil drain passages, if my other sources are correct, and have to beat/cut my firewall, and all the electronical stuff. Have any of you done this swap personnaly? If so can you help me out? I would greatly appreciate any help.
Thanks,
Tyler
N
n3rd702
N
n3rd702
Where are you located, Tyler?
dcollins311
your going to have to turn the turbo 180 degrease and when u do this ur compressor outlet will be pointing rite n to the exhaust manifold. so ur going to half to turn the compressor housing. then the waistgate want work. so ur going to half to use a exturnal waist gate. try this
