So after few years of Mukuni carb issues I am done.
Anybody know what you need for an FI set up? As in what car do I grab the manifold from and management stuff out of?
droppedmitsu
what engine do you have, 2.6l g54b or 2.0l g63b?
chriscarpenter
2.6 with an automatic transamission.
From what I understand some eclipses were running this block, and the heads are pretty much the same. I need the intake manifold and whatever MAF they are running, be it anolog or computer controlled. Everything should swap right out with the exception of maybe a bracket or two?
droppedmitsu
No they are not the same, the 2.0 are the same block as some eclipses. You need all the equipment/wiring/ecu from a starion/ or conquest which were also 2.6 g54b but f.i.
