Harmonic Balancer ?
18 following
kao71k95@yahoo.com's avatar
Harmonic Balancer ?
95toyota's avatar
95toyota
ya i was wondering wat a Harmonic Balancer does ? and would that cause ur truck to run shitty?
vegasyota94's avatar
vegasyota94
hahahahahahha
framescr8pintoy's avatar
framescr8pintoy
ask vegas he's the king of the harmonic balancer
spark show's avatar
spark show
Mine split into 2 pieces. It sucked ass.
cable's avatar
cable
lol
assdragginsdime's avatar
assdragginsdime
soo what exactly is the big joke with the harmonic balancer? i always see it mentioned on the forum. and i have no idea whats going on..
vegasyota94
i needed one up until awhile ago, and oldskewl was supposed to send me one... 2 yrs went by and i just would mention it in every post, and he never sent me one... i finally got one from framescr8pintoy...
twisted minis's avatar
twisted minis
It was pretty damn epic back in the day. You gotta be an OG member to get it. Lol.
stll2hi's avatar
stll2hi
I know, someone please explain.....
no1lowr's avatar
no1lowr
he really wants to know what it does you idiots. but vegas is a douche none the less.
A harmonic balancer (also called crank pulley damper, torsional damper or vibration damper) is a device connected to the crankshaft of an engine to reduce torsional vibration.
Every time the cylinders fire, torque is imparted to the crankshaft. The crankshaft deflects under this torque, which sets up vibrations when the torque is released. At certain engine speeds the torques imparted by the cylinders are in synch with the vibrations in the crankshaft, which results in a phenomenon called resonance. This resonance causes stress beyond what the crankshaft can withstand, resulting in crankshaft failure.
To prevent this vibration, a harmonic balancer is attached to the front part of the crankshaft. The damper is composed of two elements: a mass and an energy dissipating element. The mass resists the acceleration of the vibration and the energy dissipating (rubber/clutch/fluid) element absorbs the vibrations.
Over time, the energy dissipating (rubber/clutch/fluid) element can deteriorate from age, heat, cold, or exposure to oil or chemicals. Unless rebuilt or replaced, this can cause the crankshaft to develop cracks, resulting in crankshaft failure.
There has been a trend at times by some "performance enthusiasts" to remove the harmonic balancers on their cars. The argument is that they aren't necessary and their mass reduces the performance of the engine. Others argue that this is not worth it, because the danger of damage to the engine from the vibrations the damper is intended to prevent is too high.
While net engine output can be increased without harmonic balancers, in professional race cars harmonic balancers are still commonly equipped, for reasons ranging from safety concerns to regulations. Almost all modern car manufacturers, even "performance" car makers and specialty tuners, include a harmonic balancer on their vehicles, and removal voids vehicle warranty.
