Page 1 of 8
Toyota Pickup Projects \  RDGR8A
RDGR8A
views 13469
replies 77
following 27
hood   +1y
Owner - James Hood
Club - No Regrets NZ Chapter
Designed by - The Drop Shop
Built by - The Drop Shop
Viair 420c compressor
7 gallon 3/4" port tank
1/2" Parker fill valves
1/2" Parker dump valves
Parker line, fittings and filtration
RE-6 Slam Specialties bags up front
RE-7 Slam Specialties bags in the rear
TDS 9 function billet controller with aviation style security plug
Adjustable PSI switch
Viair gauges
When the design was being drawn up for James truck we looked at the things James wanted and one of the major things was the idea and theme behind the number plate RDGR8A. James had picked this plate for his truck as he thought the idea of a road working machine such as a road grader and the fact that his truck would also be performing such road levelling duties had alot in common and suited the truck perfectly. When talking about this it was decided that we would fabricate and install a hefty box section bridge to match the heavy duty construction of a real road grader. A TDS tri link set-up was fabricated with a design in the top wishbone link that matched in with the bridge. The rear frame rails were removed and a TDS rear clip now resides in their place. The front end has had a complete rebuild and now lays engine cross member without drop spindles and has the now infamous Drop Shop negative camber look to it. A new trans cross member has also been installed. A smaller brake booster now helps stop this rig and all new brake lines and fittings have been hooked up. James is a dedicated minitrucker and has become a very good friend of The Drop Shop and also a valuable member of No Regrets NZ Chapter.
Post was last edited on Oct 18, 2007 11:10. This post has been edited 5 times.
slammedcivicsi   +1y
looks sick, that rear bridge looks awesome. What wheels are those ? They look good.
hydroyota   +1y
sick congrats on mag coverage
northerntoy   +1y
nice ride
vegasyota94   +1y
congrats man.. shit looks bad ass
hood   +1y
Cheers, pretty proud about the feature
yota93   +1y
looks pretty sic
hood   +1y
Thanks all for the props
No updates as of yet, but its off to my panel man soonish
smctoy   +1y
Damn...I love this truck!!
hood   +1y
