Yet more work to be done
gkellison46@gmail.com's avatar
truck action's avatar
truck action
Now I have to repair rear damage ,along with repaint part of the dash !!
truck action
Also almost ready to do the front brake up
truck action
Will change to 1" master & replace the booster @ the same time
kdcgrohl's avatar
kdcgrohl
nasty abrasion. parts look killer, very nice rotors.
smctoy's avatar
smctoy
new parts look awesome & what happened to the back??
truck action
The garage door wouldn't open( cable problem) so I had to back the truck up as far as possible, & went a little too far,into a file cabinet!!
truck action
The calipers are Toyota 4-Runner 86-95 ,4-piston,the ones with 3 raised lines on the front. Will run these until brackets for the Wilwood 4-piston calipers are made (someone else is havening them made)!
slammedtoys's avatar
slammedtoys
did you get your brackets off that kid on toyotaminis.com?
phatboislim
THE CALIPERS FROM THE 4RUNNER USE THE SAME BRACKETS AS THE 2WD P/U?
truck action
Yes to the brackets, & stock brackets will not work, as going from a stock size rotor 9.25" to a 12.9" rotor. The calipers have to be moved further out! Also the stock rotor mounts behind the hub, with the Wilwood rotors & hats it mounts in front,the hats are the correct offset to set the rotor close if not @ the stock point.
