camber...
camber...
phatboislim
is it possible to get camber if you arent bagged? negative camber..i want some negative camber..i dont think any more than 1degree so my wheel will give me added clearance when i get them
twisted minis's avatar
twisted minis
Shim the upper arm.
phatboislim
meaning use washers and longer bolts right? thanks seth
slammedtoys's avatar
slammedtoys
why the hell would you want camber? That wears the hell out of your tires.
vegasyota94's avatar
vegasyota94
do we really have to answer that??
because, its Phatboi!!
kdcgrohl's avatar
kdcgrohl
the bolt are long enough. use shims. so you dont have to take the bolts all the way out. you do realize you are totally screwing up your alignment on purpose right? if you proceed, bust out the dial caliper and make sure you add the same width front to back, so you don't fuck up any other parameters.
DK
diabolic kustoms
buy a volkswagon
phatboislim
do u recommend just taking it to a shop and have them do it 'correctly' so to speak
kdcgrohl's avatar
kdcgrohl
you're gonna have to find a shop where they're willing to do this on purpose. you may have to try a couple.
hotlavaxb2089
you can put the shims in there yourself but you might mess up the caster because on the toyota the upper arm controls both caster and camber.
if you want negative camber take it to get aligned again and tell them to do it and makes sure the caster is right.
camber wear isnt as bad as caster wear.
