Yota 2.4L 22-RE I4 \  starter
starter
views 2688
replies 14
following 7
low yota   +1y
when its cold my starter just goes click i thought it might have been the relay so i got a new one that wasnt it when i was at the junk yard today i found a starter (my junkyard sucks only 6 yotas!!!)i thought my seliniod was bad so i was like what the heck i can try it so i pulled it after the long battle to put it on(my front bag setup SUCKS)i go to turn my key *click* but it turned over right after the click took a while to turn tho a lot lnger than it should have well long story short does anyone know what my problem is? and is this starter bad or is it cause its probably sat for a long ass time? thanks guys
twisted minis   +1y
Check the connection on your battery. I had a similar problem. My hot battery cable was one of those cheap clamp on ones, and the accessory attatchments weren't attatched very well. If you jiggled that cable it would start. So I bought a new one for like $8, with the stock cable outlets and the stock length. Haven't put it on yet, but I'm pretty sure thats why I'm having issues.
misfit_toy   +1y
i would go with what twisted said but i also would check the CCA on the battery and the charge of it
phatboislim   +1y
yea our trucks seem to have problem with the battery connections i almost did the same thing w/ the starter AND alternator
truck action   +1y
You can get new contacts for the starter from Toyota, about $4 ea. Or replace it with one from Toyota. Don't use any other as it will go bad quick. Remove the cover on yours & check the contacts!
I replace mine twice before going to Toyota!!
phatboislim   +1y
yea but 9 times outta 10 its the battery connection that gives us problems. im pretty much on everything original except oil, radiator fluid, water pump, brake fluid, and air filter
twisted minis   +1y
I actually bought a stock refurbished one. I also have a refurbished 22R starter if anyone needs one. At least, thats what they said it was. Could be wrong, they said it would fit my motor... Got a refund.
low yota   +1y
well im that 1 in 10 that doeasnt have trouble with the battery its 2 months old and its got a good charge the clamps on my cables are also new and they anre tight the hot is gold plated so i woulnt think about it not having a good connnection so i guess its either my starter or a connection to my starter cause this mornin i was tryin to jump it from my moms car and it was still really slow and then i messed with the wires going to it and it started but after school i couldnt get it to start messed with the wires and nothing so im not sure
truck action   +1y
If the battery is at 12.5 volts, & you have good cables( all stock),you should be good to go. I have a relocated battery( yellow top) & all the cables are 0 ga.
Must have 12.5 volts at the battery!!
low yota   +1y
i do its relocated but i have 12.5 i already checked
