Air Ride Suspensions \  check valve
check valve
Air Ride Suspensions Q & A
views 265
replies 11
following 10
BggdNBdyDrppdJunk   +1y
where do i find a good, cheap check valve, and is it a common sense thing to set it up?
eks10BDRG-N   +1y
ekstensive metal works, 850 psi i think, 281-442-1050. Yea its a good idea to put one in.
impactsus   +1y
www.innovativeairsuspension.com. Larrys got 1/2" and 3/8". They show the 3/8" on the site,but he has 1/2" also. Around $15.00 or less. can't beat that.
id need the 3/8", is the valve adjustable? i feel a little retarded asking this, but what psi should my tank hold? its either a 3 or 5 gallon tank, im pretty sure its 5
ExplicitDesignz   +1y
May be a rating pressed into the tank somewhere. But the check valve isnt adjustable or anything. It allows flow one direction, blocking it in the opposite direction.
ramslam1998   +1y
you can get a check valve at your local napa auto parts about 35 buck i think
flik68AR   +1y
suicidedoors.com has check valves for 22.99...3/8" and 1/2" anything from there is great stuff
i have to hook it up to the battery right? or is that a different kind, thanks for all the help guys
DBLT8K   +1y
lol no you hoook a check valve up between the air tank and the compressor so that the pressure in the tank isn't working against the head on the compressor, i think your thinking of something different
lowyota   +1y
I think you are wanting a pressure switch. Go to home depot the square D adjustable one is the shit DeRrIcK
