22r/22re/22re-t tranny compatiability
phatboislim
what supra tranny is compatiable to the 22r/22re/22re-t engine, i heard it somewhere before but im not too sure. im looking so that hopefully ill be able to replace my tranny at the same time that i replace my clutch, any help would be appreciated
3tcrob
do youhave a 4-speed now? All the trannies are the same just bolt them in clutch flywheel and driveshaft from like 80 and up IIRC Celicas will work as well W58 anyone?
3tcrob
Oh also they have to be 2wd not 4wd the transfer case is built into the tailshaft of the tranny
phatboislim
yea i have the homo 4, thanks on the info about the 4wd, i was about to bid on one on ebay...so any w58 tranny correct..thanx
3tcrob
Yeah W58 the 4 spd is good cause it has a lower 1st gear so it will acc quicker you may get dissappointed with a 5spd it won;t feel as quick depending on what gears you get in the trans
phatboislim
i need better gas mileage, but i have heard about a older supra transmission bolting up to our engine, that was the main reason for me asking this question..
yea i kinda know that the 4spd is kinda built more for torque/pulling, so first gear will definitely have better acceleration than the 5spd
phatboislim
toyota p/u tranny=22r/22re/22ret=w55=2002-2004 lexus is300=t34 40tN355
toyotaman89
What can i use for taller gearing on my truck?? I am sick of pulling like 3000 rpms at 70 mph... do i need to change the rear end out, or swap trannys? anyone know what will work? Just for the record i have a 5speed and im running 205/40/17's....
phatboislim
wow wish i could help you w/ that..sounds like me in my 4spd
holcombe347's avatar
holcombe347
dang dude, try runnin a 4 speed at 75...it sounds like it wants to let loose. lol. i wish i had a 5 speed.
