front a arms on my s-10
14 following
TIMS10PROG
Edited: 8/23/2005 1:41:13 PM by TIMS10PROG
ok recently i chopped my front springs and it rides like shit of corse but i just noticed that my a arms are sittin on the frame what do i do to fix this without lifting it back
Morales8907
you must of chopped like half of the spring off to get it to sit that low. thats how mine is with bags and im tuckin a lil bit so i have no idea how you even turn with it that low. but im gettin some pre modded lowers from my freind so yea i dunno about the whole spring ordeal but yes you can chop out a section of the control arm but not to much because you have to reinforce it again.
TIMS10PROG
do you have eney pix of the lower arm i dont want to f*** enything up and is that safe i can turn a little until i start rubbing and its an 82 if that matters
TIMS10PROG
come one sumone must haves som pix at lest some info
Morales8907
well mines a 95 so i cant really help ya cuz ya didnt specify, and yes it is safe if you reinforce it correctly but as far as pics i dont even have my modded arms yet so no pics sorry man keep askin people though or just go with bags
TIMS10PROG
does eney body else now what to do or have eney pix its an 82 s-10 v6
TC29720
First, don't notch your control arms. Second, I would suggest getting a little bit less of a drop (unless you switch yo bags of course, but if you wnat to keep it, notch out the frame instead. Your frame is a lot stronger than your control arms, plate it up good and you're set.
TIMS10PROG
do you have eney pix and what kind of metal do you use is it hard to do all i have is a 110 mig welder is this good enough
sadexcuse4s10
second, go ahead and cut the humps off of your control arms and plate them, i did mine and haven't had a single problem
yeah, you can trim the frame, which is strong, but after you trim it, it's cut forever....if you cut the control arms and plate them, then decide to change back to stock arms, just go to the damn junkyard, can't say the same if you decide you don't like your hacked up frame later on
TIMS10PROG
do you have eney pix of the arms
s10
last post by baha +1y
