Air Ride Suspensions \  54 caddy
54 caddy
Air Ride Suspensions Q & A
views 168
replies 5
following 5
Drgnbxchvy   +1y
I am going to start making a list of stuff for my caddy to bag it... I just want a simple clean setup.... I am going to 2 link the back... which bags do u think will work the best... Also i will be running a engine driven compressor
DodgeRT   +1y
Baggs: conitech
david49910   +1y
conti's or slams
draggindakota   +1y
What up Herbie? What size wheel/tire are you gonna run? Do you need a crap load of lift? Or do you want a simple nice ride?
I'd say if you don't need tons of lift, run F9000's behind the axle, and run super pivot ends on the 2-link so it doesn't bind as much. Is the front independent? If it is I would run Slams up front, to get more lift.
Drgnbxchvy   +1y
its 4500lb car so i know i need big bags to get lift.. i want a nice ride... and the front is independent
no1lowr   +1y
spend the money on some 2600 conti-tech 4 plys, make sure you use braided line in the front, my 69 will melt that shit in the engine bay if its not braided, or sleeved with anything heat resistent. go with some 1/2 inch parkers, and 1/2 inch setup, 2 tanks and an engine driven, its kind of an elaborate setup but you will be glad you did, the caddys are so big thaey take a lot more psi and air to get em up, plus make sure you go with good parts because you dont want a 5000lb car doing anything funny at 60mph. you know? good luck email me if you have any questions or need help with gettin the parts. rail_it_customs@yahoo.com
661 492 1141
