Air Ride Suspensions \  Mighty Max Spindles
Mighty Max Spindles
Air Ride Suspensions Q & A
views 268
replies 7
following 8
BankruptRam   +1y
Which ones to go with? Any Suggestions? And who's got the best price? AIM? Or someone on here?
brknbln   +1y
I belive AIM is the only maker out there I havent seen anyone else...
rimtucker   +1y
I have had my AIM spindles since about '94 or '95 and they work fine. Hope this helped let me know if you have any other questions I might be able to help you with.
nvrdoned50   +1y
your best bet would be to get the control arms from BarnYardCustoms. spindles will be hard to find unless you find em used. you can buy just the uppers or lowers or both. im gonna order the uppers and lowers so they will fix my -camber and still allow me to run my mazda rims untill i get 18's
dragaholic   +1y
Shaim spindles here, if youre running a small wheel be prepared to grind some a-arm. Barnyards would be nice as well.
mitsu94   +1y
u can get 2" drop spindles from www.airbagit.com for mighty max 4 188$
DawgsledMazda   +1y
my arms will lay 20s on stock spindles. if you can get drop spindles that allows you to keep the upper bag mounts lower tho. plus we just redesigned the lowers to have no tabs to weld on. only have one tube that welds on the frame and mounts the arms and eliminates the strut rods. mike@builtbybyc.com
CustomParts   +1y
I got those spindles for $175 if interested.
