Full-size lay frame 22s
13 following
shibby36
I have a 93 chevy Silverado and I was wondering what it would take to make it lay frame. It is already bagged. Right now the tires are touching the inner wheel wells. What do I have to do to make it go lower? Do I need to cut the firewall? I know the wheel wells are going to need to be removed. Is there anything else I need to move. Is the break booster going to be in the way. Oh ya I have 265/35/22 tires. Thanks for any help.
shibby36
Oh ya, it has 2 inch drop spindles in the front.
jcbrob's avatar
jcbrob
it will all u have to do is remove the inner fenders and either tub the fire wall or us a bfh and beat it in ....should lay after that
STUD1Y's avatar
STUD1Y
and you're going to have to cut your fenders inside skin up on these too.
otherwise, you won't lay. (88-9
aftermathdragr
u also need to notch the frame for your tie-rods and your control arms
shibby36
what about the brake booster im i going to have to worry about that. Also I noticed that there are some hard and soft lines for the air conditioner will those be a problem or will they be pushed out of the way when the truck drops. Thanks again
bdydrped's avatar
bdydrped
yes you will have to get a smaller booster or like dude said get a bfh and beat on it some( not recomended at all) and you will have to tub the firewall to get it to lay and not rub anything.
shibby36
where do i go about finding a smaller brake booster
mazberrydelight's avatar
mazberrydelight
you'll also possibly need to move the wiring harness on the driverside up a bit
shibby36
I was wondering how do you move the wiring harness can you just move it up or is there more to it, also does anyone know about the hard lines like I talk about before. Anything else I should be watching out for, also moveing to the back am i going to have to raise up the gas tank. How do I go about doing that. Thanks for the help
