Dodge Trucks \  Front Bag pics?
Front Bag pics?
Dodge Trucks Make Specific
views 268
replies 11
following 5
kevin@aac   +1y
Iv been searching through the profiles looking for front suspension set ups. Im going to run 7" Slam bags and make all the mounts. I have a 2002 and want to know if I can lay it out on stock control arms?Warrantee killer has some good pics in his profile, anyone else have any good ones?
low mazda   +1y
yeah, I need some help on this too. I got a buddy wanting to bag his d-50... Anything else gotta be done like raising gas tank or crossmembers or anything?
Low_SST   +1y
you guys need pics of 2 different vehicles, blitch you can basically use the same setup in the d50 as a mazda there basically the same dealio.
bagged why dont you pm dave and ask him for more detailed pics or something.
slammitsu   +1y
They are a little bit different.
Blitch, if you want more info you can go HERE
Thats for the front setup. Just got to make sure you cut enough of the spring pocket out (Thats either if you are using cups, or flat plate brackets).
As for crossmembers, there is one that will hang down, and the gas tank might. I cant remember if it does or not.
kevin@aac   +1y
My biggest question is "Can it lay with stock lower control arms? Or do I "need" DJM lowers?"
rabounce   +1y
Like you said i had nice pics.. you notice the stock arm i had..
So yes you can lay it with stock arms,
But you will need to raise ball joint when you do this , Flip the tie rod end.
If have anymore questions shoot me a pm' i'll try to help ya out.
kevin@aac   +1y
So yes you can lay it with stock arms, But you will need to raise ball joint when you do this , Flip the tie rod end.
So why did you add the tubular control arms?
rabounce   +1y
It is shortend 2 inches , So this helps my negative camber,
WIth the arms and raising the upper control arm mount it cut my nc in have from -14 degrees to -7.
kevin@aac   +1y
David, thanks for all your help! Im going to start on it this week, Iv got all my parts in.
I have a question about fliping the lower balljoint with stock lower control arms. Whats envolved? Also I have 22" rims and I want it on the floor. I realise I will have to notch the frame a little so the control arm can swing that far.
Low_SST   +1y
no you will need to z the frame
