94 Ram fuel cell
JanceCustoms@hotmail.com's avatar
94 Ram fuel cell
Jance Customs's avatar
Jance Customs
Where can I get a fuel cell for a 94-01 Ram that holds at least 18 gallons?
1 LoWfUKn RaM's avatar
1 LoWfUKn RaM
summit racing if u need a fule pump and regulator i know some one thats selling theirs chickdrag too is sellin hers go hit her up
Jance Customs
What all do you need when you use a fuel cell?
Low_SST's avatar
Low_SST
you can get the 19gallon rci fuel cell and then remove the sender and drill a hole for your fuel pump to drop into and then just space it up 1/4" and make another plate to clamp it down. Ill have mine done this week sometime hopefully and ill post pics.
1 LoWfUKn RaM
fuel pump and regulator sending unit maybe shes selling everything u need for it to werk except a cell
Jance Customs
Edited: 11/18/2005 10:44:40 PM by jancecustoms
Edited: 11/18/2005 9:09:05 PM by jancecustoms
Edited: 11/18/2005 9:05:04 PM by jancecustoms
Low_SST Where are you going to mount your cell? I am going to put it where the spare tire mount is.
I think I found the same tank on summit. http://store.summitracing.com/default.asp?Ntt=fuel+cell&Ntk=KeywordSearch&DDS=1&searchinresults=false&N=115&target=egnsearch.asp&x=10&y=12
1 LoWfUKn RaM
im mounting mine there too i think mostly
every body puts them there
jeff davy's avatar
jeff davy
Devious customs will make you one with your stock fuel pump and sending unit. deviouscustoms.com
Low_SST's avatar
Low_SST
yea mine is going between my frame rails and it fits perfectly. mine is 12x12x30 and i believe its 32" between the rails. Its very simple to get it to work.
Jance Customs
Where are you guys planning on running your filler neck? I was thinking on inner bed wall for mine.
