hopsing
^^ no you cant cut a strut itself to shorten it. You can however cut off the mounting tabs if you have a Macpherson strut and move those up to lower the vehicle. BUT, you could ruin the strut from the heat of re-welding the tabs back on. Also, you may notice that it says to not heat the strut, it is under pressure. And also, if you dont weld those tabs on there good you'll be in a world of hurt when your wheel falls off going around a corner. Also, I cant believe you actually told someone from KUSTOMWERKS that what he said was not correct! And I do agree, either modify the upper strut tower mount by raising it, and/or modify the bearing mount assembly by making it shorter as well.
