Isuzu \  Reverse 4 link Bar Lengths - 92 Isuzu Pickup
Isuzu Make Specific
views 1133
replies 19
following 11
slamsuzu   +1y
Im getting ready to install a 4 Link on my 92 Isuzu Pickup. Does anyone know the 4 link bar lenghts for an isuzu pickup? Anyone that has successfully installed a 4 link, would you please let me know your bar lenghts to I can get everything order correctly.
Thanks,
Joejoe@rmhuffman.comwww.dedicatedcc.4t.com
balcar   +1y
just measure from the front spring perch to the middle axle, and get for bars that size. Install them forward, not reverse.
slamsuzu   +1y
Phil, What wrong with installing it in reverese? Ive seen a million mini trucks with them in reverese. Does installing it in reverse work with the same concept you posted above? Thanks for the reply.
balcar   +1y
search the forums, it will explain everything to you, this has come up a BUNCH of times. If you are building a trailor queen then reverse is fine.
dragn168   +1y
i too have seen alot of trucks with reverse 4-links but the thing with reverse links is the fact that when you air out your truck the reverse link pulls the drive shaft out of the transmision you can do a reverse but it takes alot of work to get it to work right but also i need the bar legnths too cuz im bout to 4 link mine and i need to know what legnths the bars should be
mmrcustoms   +1y
put them to the ft.
balcar   +1y
if you have a trailor queen, go ahead and put them back, but if you are going to be driving, dragging, lifting all the way, etc, its best to do them forward.
mmrcustoms   +1y
my measurement is 27' over all and i mounted the axel at 23'1/2' but i am running my bars forard
mmrcustoms   +1y
i am running a 2 link with panhard
balcar   +1y
mmrcustoms- time to upgrade to a 4-link... LOL
