shaving without welding?????
23 following
str8down01@yahoo.com's avatar
str8down's avatar
str8down
is there such a thing? I have a friend that had his doors shaved at a reputable body shop and the used some type of filler! No welding!!! 1 yr later still no cracks or anything, anyone know what might have been used??
lownism0
probably a panel bond. Its an adhesive they use to put bedsides and sometimes on place of quarter panels on.
bodydropped85's avatar
bodydropped85
panel bond. 3m panel bond 8115
str8down's avatar
str8down
anyone know where i can get this stuff
Low_SST's avatar
Low_SST
seems ghetto to me. i would weld and metal finish because nothing would beat having a friend slam the door and have the filler pop out.
dragndodge's avatar
dragndodge
Mine have been done for almost 3 years and I have not had any problums with the 3mFlorida
milkman64's avatar
milkman64
we used this stuff at the body shop i used to work at.i have put roof skins,bed sides,quarter panels,al kinda stuff,it kicks but! no way are you going to slam a door and this stuff let loose.check with youre local paint/body shop supply store they should be able to fix you up
KEEF's avatar
KEEF
The hole shows when it gets hot unless u weld/metal finish em.......
PsymonSez16
OK, I have never heard of this, So what you are saying is I can get some of this and shave my owns handles even though I don't know how to weld.
milkman64's avatar
milkman64
we had a filler made for the glue,it was kinda like kitty hair but made by the same company as the glue.it is possible for the handle to still show,i never thought about that,i have seen alot that was welded that still showed also
