Page 1 of 3
Nissan Trucks \  battery light
battery light
Nissan Trucks Make Specific
views 457
replies 29
following 9
bdroppeddak   +1y
what does the battery light on the gauge cluster mean? i have a 94 hardbody, and ive changed out the battery, but the light still stays on.
jkuczek   +1y
It could be your alternator. You can go to Autozone, O'Reily's, etc. and have it checked.
fatboysS1O   +1y
Advanced Auto/Autozone whatever the hell it is this week will check it for free!
jkuczek   +1y
Edited: 7/22/2006 6:22:19 PM by jkuczek
First off...Did you have your battery tested because it may not have been bad?
Also it may be different for other areas, but the Autozone I work at will check it for free any time/not just during special weeks. They can check it while in the truck and can also bench test it if it's not installed.
dssur   +1y
On 94 Nissan there is a fusable link at the battery post, the end always corrodes. I have had three Hardbody's and all three had this problem. Weak connection due to corrosion, turns on the batt light.
You DONT need the special connector, on all three Hardbody's I just snipped the "special connector" off and put a ring terminal on. If you have powdery shit at the + terminal this is your problem.
DougIVKS also had one that the wire at the back of the alternator corroded and a ring terminal there fixed him too. But I thik his was a slow discharge/no start in the morning problem.
bdroppeddak   +1y
are you talkin about that black 3 prong plug?
bdroppeddak   +1y
welp im pretty sure it was the alternator, my truck died on me on the way to work this mornin, gonna have fun when i get off!
dssur   +1y
read the battery voltage and then probe the wires one by one a little ways away from the battery. If you alt wire shows 14.4 and the batt is only at 11, its the connector.
bdroppeddak   +1y
hmm well when i find out where it got towed to, i'll get it home and test that shit before i spend 140 dollars on an alternator. what fun today was!!!
fatboysS1O   +1y
sounds like youve got my kinda luck! im in the middle of rewiring my whole truck right now cuz of gay little problems like that.
